| | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62639 07/07/2006 4:23 AM | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | Does anyome have a reference to check bellhousing casting numbers? I'm trying to figure out what I have here. It's cast iron and has the 50's era crossmember mounts cast in.
The casting number is: 3733373 The date code(?)looks like: L 1 6 Other marks: GM1
I'm really trying to determine what year this is and whether it's a truck or passenger car bell housing. Any help would be greatly appreciated! | | |
#62640 07/07/2006 5:04 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Old Gold, I could not find that number in my books from 55-59, I'm assuming from the date code it was made in 56. Quite often casting numbers are not the same as part numbers. Could you give us some more clues, is it a V8 or 6 housing, does it have an angled mounting surface or is the mount surface parallel to the ground, is there one hole in each mount pad or two? | | |
#62641 07/07/2006 5:14 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Can you post a picture? That might help as well. I think 3B is on the right track that it is a '56 casting. Possibly November 1 1956. Hmmm, that would actually make it a '57 part.
Bill Burmeister | | |
#62642 07/07/2006 7:07 AM | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | Thanks for your help guys. It's for a V8. The mounting pad surfaces are slightly angled and there is only one bolt hole in each mounting pad. Does that help at all? I will try to post a pic tomorrow. | | |
#62644 07/07/2006 9:52 PM | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | That bellhousing 3733373 is for trucks 8 cyl. 1955-59. | | |
#62645 07/07/2006 11:13 PM | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | Thanks chevyb! I was hoping that was the case, 'cause that's what I need! Can I ask where you found your info? Thanks again. | | |
