3 members (panic, 2-Ton, 1 invisible),
133
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62636 07/06/2006 11:03 PM | Joined: Feb 2006 Posts: 5 Junior Member | | Junior Member Joined: Feb 2006 Posts: 5 | Hello, I am in need of some help here and any information will be appreciated. I have a 49 Chevy ½ ton truck that my brother-in-law and I recently worked on. We took off the manual transmission and all of the linkages. We encountered a problem when we went back to reassembling the clutch. While the transmission shifts gears normally, my problem is that the actual clutch pedal wobbles when I press it with my foot. It does not press in straight. It feels flimsy. There seems to be some play where the clutch shaft goes through the floorboard. Am I missing a bushing or something? I hope that I am explaining myself? Has anyone had this problem before? Like I said earlier, any help would be appreciated. | | |
#62637 07/06/2006 11:26 PM | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | There is indeed a bushing between the clutch pedal and the shaft - and possibly it's fallen out or disintegrated over the years. Replacements available through the usual parts suppliers.
There's also a spring that goes between the clip at the end of the shaft and the pedal, and I know mine tried to make a getaway when disassembled.
Finally the pedal itself has an adjustment bolt, be sure that's tight too.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#62638 07/07/2006 8:13 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | I posted my experiance on this same problem on the general Truck Talk, where you also posted. goodluck. But i saw no adjustment other than the clutch free play.
"It ain't a truck if you can't hose out the cab."
