| | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | im getting ready to look at a rear that i might be able to use. the rear is a 41 one ton eaton ten bolt and has GM4 3682126 stamped in it someplace from what i was told. i looked in the mpb and i didnt see it listed not to say i scanned past it. i didnt even see a one ton section in the 41 maint manuel | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Mike, that number comes up in the Chevrolet parts book. Casting number 3682126 =group no 5.505 p/n 3682125 but I can't take it any farther. I will look for my oldest Hollander. Maybe it will go back that far.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Mike, I found an old Hollander. It doesn't list a 1 ton Chev, but it does list GMC. 1 ton GMC used the same rear end from 41 to 48. They came in 4.12, 4.86, and 6.67. The same third member shows to fit a 40-47 Ford and a 48-52 Ford. The fact that it interchanges with Ford leads me to believe that this would have been an Eaton. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I would have to check to be 100% sure about the years, but I know that there are a few points during the late '30s/early '40s that Chevrolet did not build a 1 ton truck, other than a "1 ton Special Panel", which was more af a downgraded (sigle wheels/no overloads) 1 1/2 ton. Along those same time points, GMC did not build a 1/2 ton truck, as GMC didn't build "light pickups". That was not counting the "1/2 ton Special Delivery (Buick type).
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | after going to look at the unit i found it had 8 lugs. i need 6 lugs. im looking to find a one ton rear that has the third member to change out the ring and pinion and will acomodate duallys. as of now i have a split timlin rear and a ring and pinon change cant be done on the timkin. i know there is a rear out there somewhere from a cc and ec gmc model years. | | |
