| | | Forums66 Topics128,022 Posts1,055,381 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 105 | Hi, I am trying to figure out how to install the chrome conduit like these for my tailight wires on my 51. Anyone have any pictures of them installed on their AD truck? Any help is much appreciated. Thanks! Chris | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Mine isn't an AD, but here is how mine is done.
Bill Burmeister | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I did mine basically the same way. I used a rubber grommet in the back of the tail light just about the same size of the smooth end of the conduit and pushed it into the gromet from the outside back end of the tail light. On the end that goes into the frame, I used a hard plastic grommet that has a hole in it so the conduit fits snugly through it but stops because of the flare on that end of of the conduit, then I pushed the grommet through a hole in the frame on the outside of the frame and it just snaps in. I found these grommets at the Ace Hardware Store near my place.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: May 2009 Posts: 135 'Bolter | | 'Bolter Joined: May 2009 Posts: 135 | 1935-1939 trucks had a conduit installed on the wiring harness to protect the wires between he body and the tail lamp. On the forward side of the lamp there was a bracket with a keyhole shaped slot to receive and retain the lamp end of the conduit. I believe Jim Carter and other suppliers sell a reproduction of this item. The problem with using it on your AD is that the lamp bolts are diagonal to one another, whereas the '35-'39 truck lamp had bolts in a straight vertical line. Check it out. If you can't find one, let me know and I will post a photo of mine.
Mike
