2 members (2-Ton, 1 invisible), 108 guests, and 2 robots.
Topics128,034
Posts1,055,546
Members48,425
#62554 07/05/2006 8:32 AM
I have a 41 Sedan and I belive I have an stock sending unit.
The unit was bolts into the original 216 engine and also in the 235 without any adaptor.
Now I have the 848 head and it looks like I need an reduction bushing.
I found one in a spare head but it was to big (outer diameter).
Are ther different sizes made?
HELP!
Thanks, Frank
#62555 07/05/2006 9:39 AM
you can probably find one that works in a new aftermarker temp gauge, they usualy come with an adapter or two.
1952 Chevrolet 3800 pickup
---All pictures---
#62556 07/05/2006 11:06 AM
No way, over here in Germany you can`t buy such things frown
#62557 07/05/2006 2:58 PM
yes and they should be pipe thread... NPT
you may want to re-thread the bushing so the original /new sender can fit further in, so the probe is clear of the threads on the bush and water hits the tip.
you want the end /sender in the water's flow otherwise there is a dead zone and the tip will not sense the correct temp of the H2O.
local hardware stores have plumbing fittings.
Jim & Caroline
