| | | Forums66 Topics128,031 Posts1,055,435 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62554 07/05/2006 8:32 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | I have a 41 Sedan and I belive I have an stock sending unit.
The unit was bolts into the original 216 engine and also in the 235 without any adaptor.
Now I have the 848 head and it looks like I need an reduction bushing.
I found one in a spare head but it was to big (outer diameter).
Are ther different sizes made?
HELP!
Thanks, Frank | | |
#62555 07/05/2006 9:39 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | you can probably find one that works in a new aftermarker temp gauge, they usualy come with an adapter or two. | | |
#62556 07/05/2006 11:06 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | No way, over here in Germany you can`t buy such things  | | |
#62557 07/05/2006 2:58 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | yes and they should be pipe thread... NPT you may want to re-thread the bushing so the original /new sender can fit further in, so the probe is clear of the threads on the bush and water hits the tip. you want the end /sender in the water's flow otherwise there is a dead zone and the tip will not sense the correct temp of the H2O. local hardware stores have plumbing fittings.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
