6 members (Stovebolt48, 78buckshot, Shardean, GRNHydra, Ponchogl, dt235sd), 88 guests, and 3 robots.
Topics128,021
Posts1,055,349
Members48,420
#624865 03/01/2010 5:28 PM
Does anyone know if a 3/4 ton panel body can be put on a 95 gmc 1/2 ton 4x4 frame?
49panel #624873 03/01/2010 5:48 PM
You might want to indicate the year of the 3/4 ton panel.
There was no 3/4 panel in 1949.
There was a 1/2 ton panel and a 1 ton panel in 1949.
tclederman #624888 03/01/2010 7:09 PM
the panel is a 1949 1ton (It did have 3600 badges on the hood but this could have been a replacement.
49panel #624963 03/01/2010 10:44 PM
Yes any body can be put on any chassis if you have the skills to fit it. Will it just bolt right on? No. Will it look right with the wider wheelbase? Probably not.
Cletis #625095 03/02/2010 5:23 AM
Just have to ask...What in your opinion would be a good enging and frame to start with knowing that I would like it to be a 4wheel drive once swapped?
49panel #625204 03/02/2010 6:53 PM
A lot of people are using S-10 frames. Try a search of the site for S-10.
Cletis #625222 03/02/2010 7:43 PM
Apprentice
Apprentice
You might try this post on the Jalopy Journal website...
www.jalopyjournal.com/forum/showthread.php?t=274702&highlight=10
I believe the best frame for a '49 panel is the original frame. Both my '51 pickup and my '49 half ton panel have the original frames with Nova clips...
But with 4WD, an S-10 is probably the way to go...
51 1/2 ton-455 rocket!
49 1/2 ton panel-rocket-to-be!
