3 members (wilbur53, Youngin' Tut 59, delwrench), 90 guests, and 2 robots.
Topics128,174
Posts1,057,048
Members48,458
I just noticed that there is a difference between my new and old wheel cylinder inlet ports. The new one is lacking the seal rings where the copper washer rests. Pic Is this going to be a problem? Will the new copper washer give a good seal at this junction? The new wheel cylinder came from NAPA.
"Lucille" ..... Proud Member of the "Southern Stovebolts"
David Wolff
1946 Chevy 1/2-ton
Riding in the Passing Lane
You have a new washer there. It should seal OK.
1972 Chevy c10 Cheyenne Super
Wet the sealing surfaces and threads with brake fluid before assembly.
You are apparently aware of the potential for a problem or else you wouldn't have asked the question Dave. I wouldn’t think that it would be a problem, as long as you're using a new dead soft, i.e., fully annealed, copper seal to start with. That smooth sealing surface presents a greater surface area therefore you need to apply more torque to get a good seal.
The object of the rings of course, is to bite into the seal at a lower torque value to seal the same area. If you used the same torque values for both surfaces the one with the grooves will seal a larger area.
And yes, they do cut corners where ever they can with the after market parts available today. .
DG
Denny G
Sandwich, IL
