0 members (),
87
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | I just noticed that there is a difference between my new and old wheel cylinder inlet ports. The new one is lacking the seal rings where the copper washer rests. Pic Is this going to be a problem? Will the new copper washer give a good seal at this junction? The new wheel cylinder came from NAPA.
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You have a new washer there. It should seal OK. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Wet the sealing surfaces and threads with brake fluid before assembly. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You are apparently aware of the potential for a problem or else you wouldn't have asked the question Dave. I wouldn’t think that it would be a problem, as long as you're using a new dead soft, i.e., fully annealed, copper seal to start with. That smooth sealing surface presents a greater surface area therefore you need to apply more torque to get a good seal. The object of the rings of course, is to bite into the seal at a lower torque value to seal the same area. If you used the same torque values for both surfaces the one with the grooves will seal a larger area. And yes, they do cut corners where ever they can with the after market parts available today. . DG
Denny G Sandwich, IL
