| | | Forums66 Topics128,021 Posts1,055,351 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 4 New Guy | | New Guy Joined: Aug 2005 Posts: 4 | Does anyone know if a 3/4 ton panel body can be put on a 95 gmc 1/2 ton 4x4 frame?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You might want to indicate the year of the 3/4 ton panel.
There was no 3/4 panel in 1949.
There was a 1/2 ton panel and a 1 ton panel in 1949.
| | | | | Joined: Aug 2005 Posts: 4 New Guy | | New Guy Joined: Aug 2005 Posts: 4 | the panel is a 1949 1ton (It did have 3600 badges on the hood but this could have been a replacement.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes any body can be put on any chassis if you have the skills to fit it. Will it just bolt right on? No. Will it look right with the wider wheelbase? Probably not. | | | | | Joined: Aug 2005 Posts: 4 New Guy | | New Guy Joined: Aug 2005 Posts: 4 | Just have to ask...What in your opinion would be a good enging and frame to start with knowing that I would like it to be a 4wheel drive once swapped? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A lot of people are using S-10 frames. Try a search of the site for S-10. | | | | | Joined: Jan 2006 Posts: 33 Apprentice | | Apprentice Joined: Jan 2006 Posts: 33 | You might try this post on the Jalopy Journal website... www.jalopyjournal.com/forum/showthread.php?t=274702&highlight=10I believe the best frame for a '49 panel is the original frame. Both my '51 pickup and my '49 half ton panel have the original frames with Nova clips... But with 4WD, an S-10 is probably the way to go...
51 1/2 ton-455 rocket! 49 1/2 ton panel-rocket-to-be!
