8 members (68ironhead, GMCJammer51, Bill Hanlon, Gdads51, TrknGMC, 53 green 1- ton, msmall, 1 invisible), 181 guests, and 2 robots.
Topics128,086
Posts1,056,094
Members48,434
#624436 02/28/2010 5:15 PM
Yup, it's me again. I want to remove the Torque tube from my 1954 3100 4 speed Chevy truck. I have it separated at the transmission and the torgue tube is dropped below the transmission, so there is clearence for the torque tube to slide towards the front of the truck.
If I remove all the nuts around the pumpkin, does the torque tube & enclosed drive shaft come out as a complete assembly?
-Tom
1950 Chevy 3100 w/ 1956 235
Aaah! Thanks for the shop guide. Looks like I'm correct in just, drain the pumpkin and remove all the nuts around the housing and it should split apart.
Have to pull the axles free from the pumpkin too.
Thanks Greg, That will change my game plan. My objective is to make the removal of the rearend easier. I'll fall back on just disconnecting rear shackles and rolling the whole rearend and torque tube out the back of the truck.
Thanks Again
