1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#62470 07/02/2006 11:12 PM
Junior Member
Junior Member
If an engine is not cranked for 2 or 3 years can the oil pump loose its prime?
#62471 07/02/2006 11:27 PM
Not that I've ever heard about. As long as the pick up tube is below the oil level it should pump oil. If not I would suggest that the oil pump is bad.
Daily Driver 63 C-10 LWB Fleetside
#62472 07/02/2006 11:40 PM
Junior Member
Junior Member
Texmo,
Thanks for the reply. I replaced the oil pump and sending unit in 2001.It ran great for a couple of years.( I only drove it 2 or 3 times a year,just trying to keep it alive; so the oil pump couldnt have over 50 miles on it))For unforseen reasons it sat idle for 3 years. one week ago I put a battery in it ,cleaned the points, and replaced the ignition coil. It cranked without much of a fight, but the oil light is not going off. Any suggestions?
#62473 07/03/2006 12:54 AM
Try this, It only costs a filter. Remove the oil filter, fill the new one with oil before installing, it. Your filter has probably drained dry and caused the pump to fill with air also. The filter full of oil may be enough to get it pumping again. But, you have to be quick to get the filter on before all the oil runs out!.
#62474 07/03/2006 1:19 AM
Junior Member
Junior Member
Thanks KENC, I'll try that tommorrow afternoon. I'll let you know how it goes.
#62475 07/03/2006 1:19 AM
Z
Z Offline
i had a 235 that did that.i bought an underdash oil guage.it turned out to be the sender for the light.
#62476 07/03/2006 1:38 AM
Junior Member
Junior Member
Thanks zenish, is there a tool made for reading/checking oil pressure? Many auto parts stores in my area loan tools. I wonder if that would be an option?
#62477 07/03/2006 3:04 PM
Check with your local auto parts store for a cheap mechanical oil pressure gauge. There are lots of them to choose from. You won't need much over 60 psi. At the back of the engine on the passenger side, down close to the oil pan is where the senders are located. You can screw a gauge right in to the block and have a helper watch it when you start the truck.
The oil in the filter is a good idea, but an even easyer one is to squirt oil in the the block with the filter removed. It will be the outer hole, the center hole is filtered oil going out to the engine, the outer hole is from the pump.
http://surpluscenter.com/sort.asp?U...rd=yes&search=oil%20pressure%20gauge
Check the above link for gauges, Joe
#62478 07/03/2006 6:33 PM
Apprentice
Apprentice
Hi rsl-dixie-
I'm a new guy to so let me know if I'm off my rocker- I was always taught that before you start an engine that has been sitting a long time, it's wise to pull the distributor and run the oil pump manually. I use a 3/8" OAK dowel trimmed down to a fat blade, and drive it with an electric drill. For me the pump spun real easy at first until it primed, then with the lid off the oil filter I could see when the oil started to circulate. I put the lid back on, and the rocker cover off, and waited until oil started coming out of the rockers before I start the engine up. Seems to me if you did the same you could feel how the oil pump is running, and tell if you have a blockage somewhere. Anyway, a newbie's $.02 worth.
-Warren
