1 members (baldeagle), 40 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#62442 07/02/2006 7:04 PM
I got some cool Autometer gauges and I was looking at the Temp sending unit location. It seems the sender is screwed into the head near the intake manifold. Is this the correct location? I also noticed holes that are plugged in the water outlet and thermostat housing. I've looked at a lot of sixers, and the all the owners place the sender in different locations. I feel that the current location would probably give an inaccurate reading because it gets pretty hot by the exhaust manifold.
#62443 07/02/2006 8:50 PM
Riding in the Passing Lane
I take it this is a 6 cyl. in a 69. The factory used the outlet on the side of the head over the manifolds. That is the best place but you can use an outlet up front as long as its under the therm.
1972 Chevy c10 Cheyenne Super
#62444 07/03/2006 3:11 PM
I have mine in the hole between #2 and #3 cylinders on the left side of the head right above the exhaust. I don't think the exhaust has much to do with heating the sender. The tip is what reads and its deep in the head under water. Even if it does, the water is that hot anyway, so its still accurate. Mine reads hotter then the thermostat or radiator, so if the gauge shows hot, I know I have a safety margine of a few degrees before overheating. Joe
