0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
My Rochester B carb is continually causing me problems and I am thinking of updating it. Down the road, I want to make some major engine improvements, but for now is there a relatively inexpensive replacement for the Rochester B carbs? Any suggestions/recommendations are appreciated. Thanks!
Today is the best day of my life!!!
Carter yf
Just amke sure that it's the Chevy version, some rebuilders will put any carb in the box and call it the Chevy app. It happened to me. If it says "made for Motorcraft by Carter" on the float bowl, it's a ferd unit. Those run too rich for a Chevy.
Bill Burmeister
Is the Carter YF a direct bolt on for a 235? Also, is there a model number. Thanks again!
It'll bolt right on, you'll want part #2100S. Make sure to specify for a Chevy though, and check it before you accept it so you get the right one.
Bill Burmeister
Thanks for the info Bill. One last question,any recommendations on where to buy?
It looks like they may have one at Jim Carters
"All right, they're on our left, they're on our right, they're in front of
us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC
Carbking posted a list of applicable Carter YF Carbs. Do a search in the engine and driveline forum. A lot of good info.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Does anyone use the Holley/Webber 2bbl carbs and adapters from Langdon's Stovebolt? If so, do you run 1 or 2 carbs? What changes need to be made or will they bolt right on (with the right intake manifold) or do I need to change other components as well?
I'm a novice looking to upgrade and would like some guidance.
Hey
Check out 49 Geezer's post on "Plumbing in H/W's". He's got some really great pics of his process for setting up a 2/1 combo on his site.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Carter YF uses the same jets as AFB so you can easily re-jet for your conditions. Edelbrock is still making them for their clones so you can buy them most anywhere. Also, the YF model parts interchange so if you get a base you like you can put a top from another YF on it to utilize whatever mounting you have on your air cleaner. Doug
