2 members (78buckshot, Wheelie),
131
Mod | | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62426 07/01/2006 8:36 PM | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | My Rochester B carb is continually causing me problems and I am thinking of updating it. Down the road, I want to make some major engine improvements, but for now is there a relatively inexpensive replacement for the Rochester B carbs? Any suggestions/recommendations are appreciated. Thanks!
Today is the best day of my life!!!
#62427 07/01/2006 10:22 PM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | | | |
#62428 07/01/2006 11:04 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Just amke sure that it's the Chevy version, some rebuilders will put any carb in the box and call it the Chevy app. It happened to me. If it says "made for Motorcraft by Carter" on the float bowl, it's a ferd unit. Those run too rich for a Chevy.
Bill Burmeister | | |
#62429 07/01/2006 11:54 PM | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | Is the Carter YF a direct bolt on for a 235? Also, is there a model number. Thanks again!
#62430 07/02/2006 12:14 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It'll bolt right on, you'll want part #2100S. Make sure to specify for a Chevy though, and check it before you accept it so you get the right one.
#62431 07/02/2006 12:28 AM | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | Thanks for the info Bill. One last question,any recommendations on where to buy?
#62432 07/02/2006 1:01 AM | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | It looks like they may have one at Jim Carters
"All right, they're on our left, they're on our right, they're in front of us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC | | |
#62433 07/02/2006 3:14 PM | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Carbking posted a list of applicable Carter YF Carbs. Do a search in the engine and driveline forum. A lot of good info.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | |
#62434 07/02/2006 11:18 PM | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | Does anyone use the Holley/Webber 2bbl carbs and adapters from Langdon's Stovebolt? If so, do you run 1 or 2 carbs? What changes need to be made or will they bolt right on (with the right intake manifold) or do I need to change other components as well?
I'm a novice looking to upgrade and would like some guidance.
#62435 07/03/2006 12:53 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Hey
Check out 49 Geezer's post on "Plumbing in H/W's". He's got some really great pics of his process for setting up a 2/1 combo on his site. | | |
#62436 07/03/2006 2:55 PM | Joined: Apr 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 275 | Carter YF uses the same jets as AFB so you can easily re-jet for your conditions. Edelbrock is still making them for their clones so you can buy them most anywhere. Also, the YF model parts interchange so if you get a base you like you can put a top from another YF on it to utilize whatever mounting you have on your air cleaner. Doug | | |
