7 members (Hotrod Lincoln, Jon G, Wheelie, Otto Skorzeny, ShopRag, Gdads51, klhansen),
109
Mod | | | Forums66 Topics128,287 Posts1,058,544 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 8 New Guy | | New Guy Joined: Nov 2009 Posts: 8 | Hello everyone. I am trying to locate the correct front cab rubber bushings for a 1963 C-20. All I find are complete kits for a C-10,which I do not mind buying. If I knew for sure they were the same. Thank you for responding.
Dave | | | | | Joined: Oct 2005 Posts: 116 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 116 | Dave , I can't say for sure but I think they are the same . I believe the main difference between a C10 ( 1/2 ton ) and a C20 ( 3/4 ton ) is in the heavier suspension and larger wheels .I think the cab and body panels are the same between the two models .
" The heart of the wise inclines to the right , but the heart of the fool to the left " - Ecclesiastes 10:2
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i think lmc sells the same one for 1/2 and 3/4 tons. i have used those on my c20. but, i may be wrong, hopefully someone with a good memory will add something. i have seen different ones for c60's where the cab sets up off frame. | | | | | Joined: Nov 2009 Posts: 3 New Guy | | New Guy Joined: Nov 2009 Posts: 3 | Hello the front mounts are the same the rear cab mounts are different they are a shear style lots of people convert to the 1/2 ton mount on the 3/4 | | |
