Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (Jay R, Otto Skorzeny, ndkid275, moparguy, ArtA, 2 invisible), 83 guests, and 5 robots.
Topics128,287
Posts1,058,544
Members48,491
Hello everyone. I am trying to locate the correct front cab rubber bushings for a 1963 C-20. All I find are complete kits for a C-10,which I do not mind buying. If I knew for sure they were the same. Thank you for responding.
Dave
Dave , I can't say for sure but I think they are the same . I believe the main difference between a C10 ( 1/2 ton ) and a C20 ( 3/4 ton ) is in the heavier suspension and larger wheels .I think the cab and body panels are the same between the two models .
" The heart of the wise inclines to the right , but the heart of the fool to the left " - Ecclesiastes 10:2
i think lmc sells the same one for 1/2 and 3/4 tons. i have used those on my c20. but, i may be wrong, hopefully someone with a good memory will add something. i have seen different ones for c60's where the cab sets up off frame.
Hello the front mounts are the same the rear cab mounts are different they are a shear style lots of people convert to the 1/2 ton mount on the 3/4
