2 members (Peggy M, MNSmith),
240
Mod | | | Forums66 Topics128,282 Posts1,058,495 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 38 New Guy | | New Guy Joined: Jan 2010 Posts: 38 | Well I have narrowed my oil pressure problem to the oil pump. I dropped the oil pan tonight and plan on removing the pump tomorrow. I have already dissconected the oil line in the head. Any tips on removing it would be appreciated. its a 216 in a 1953 3800 (1 Ton)
If it's broke hit it harder!
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Just follow the manual if you have one. Loosen the lock nut then back out the lock bolt(pin). You might have to tap on the pump body to loosen it.You should remove the distributor first.
Drew
| | | | | Joined: Jan 2010 Posts: 38 New Guy | | New Guy Joined: Jan 2010 Posts: 38 | Ahhh I see the problem. I removed the lock nut and bolt but did not remove the distributor. I will go remove the distributor and give it a tap with my rubber mallet. thanks Drew
