4 members (dwreills, Gdads51, Otto Skorzeny, 1 invisible), 105 guests, and 3 robots.
Topics128,036
Posts1,055,460
Members48,422
#62389 06/29/2006 2:06 PM
Hey Guys',
What kind of oil pressure do you get with your 216/235 low press engines? I get 10 cold and 5 hot. Maybe I need a new pump.
Glenn,
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
#62390 06/29/2006 2:13 PM
Ex Hall Monitor
Ex Hall Monitor
First start up cold I get almost 30. As it warms up it drops to just under 15 at highway speed and about 5 at idle. I have a 38 216 with the dippers.
#62391 06/29/2006 3:41 PM
Usually about 10 at idle and 15-20 when she's working.
When we were first trying to get her started, we dragged her behind my Jimmy and in high gear, the engine got up to fifteen with no problems.
I have a '49 216 out of a car. Runs like a top, now.
What kind of oil do you have in there, and how old is it?
#62392 06/29/2006 4:31 PM
Quote
Originally posted by GEC52:
Hey Guys',
Glenn,
Yeah, that's a little low. You may want to check the oil pump and/or screen and also make sure your main bearings are shimmed correctly.
#62393 06/30/2006 6:41 PM
For the 216, you should get about 14 lbs at speed and anywhere between 0 and 7 at idle.
1951 1 Ton Completed
