| | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62389 06/29/2006 2:06 PM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Hey Guys', What kind of oil pressure do you get with your 216/235 low press engines? I get 10 cold and 5 hot. Maybe I need a new pump.
Glenn, | | |
#62390 06/29/2006 2:13 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | First start up cold I get almost 30. As it warms up it drops to just under 15 at highway speed and about 5 at idle. I have a 38 216 with the dippers.
#62391 06/29/2006 3:41 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Usually about 10 at idle and 15-20 when she's working.
When we were first trying to get her started, we dragged her behind my Jimmy and in high gear, the engine got up to fifteen with no problems.
I have a '49 216 out of a car. Runs like a top, now.
What kind of oil do you have in there, and how old is it? | | |
#62392 06/29/2006 4:31 PM | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Originally posted by GEC52: Hey Guys', What kind of oil pressure do you get with your 216/235 low press engines? I get 10 cold and 5 hot. Maybe I need a new pump.
Glenn, Yeah, that's a little low. You may want to check the oil pump and/or screen and also make sure your main bearings are shimmed correctly. | | |
#62393 06/30/2006 6:41 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | For the 216, you should get about 14 lbs at speed and anywhere between 0 and 7 at idle. | | |
