| | | Forums66 Topics128,117 Posts1,056,296 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 94 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 94 | Does anyone know where i can buy a complete bolt in mustang 2 front suspension for my 1946 chevy 1/2 ton?
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Check out Chevs of the 40s & hot rod magazines are full of this stuff. | | | | | Joined: Apr 2005 Posts: 35 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 35 | I am putting one in now from JW Rod Garage. It is not a bolt in but welds in very easily if you know someone who can do the welding for you. It would probably take you longer to drill the holes than it took to weld. No cutting of the frame or inner panels is required. They are great folks to deal with and the pricing is great. Let me know if you would like to see some pics of what i have done so far.
Mike | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | I got mine off of EBAY a TCI unit(Gone fishing is the seller) they usually offer specials which includes sway bars, choice of manual or power rack extra set of rotors (Drilled & Slotted) stainless brake lines choice of stock or 2" dropped spindles. It is a weld in kit though with some frame mods for clearance of rack.
| | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | I would like to see your kit Mike. Post us a pic. Thanks Gary | | | | | Joined: Feb 2022 Posts: 1 Moderated | | Moderated Joined: Feb 2022 Posts: 1 | Anyone able to come up with 6 bolt rotor & caliper kits for this swap, mustang 2 front end?? | | |
