| | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 153 | Added an HEI to my inline 250. Question is which wire is + and -? Pink and brown are the two leads coming out of the distributor. Also, where should I tap the tach wire into?
thanks, Mac | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | First you should be replacing the positive wire to the HEI with 10 awg wire, minimum 12 awg. The HEI requires a full 12v to coil. This has been discussed many times.
Second assuming this is not a Pertronix, or external coil, it is marked on the distributor cap Tach and Bat.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Jul 2005 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 153 | | | |
