0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#623063 02/24/2010 4:06 PM
Added an HEI to my inline 250. Question is which wire is + and -? Pink and brown are the two leads coming out of the distributor. Also, where should I tap the tach wire into?
thanks, Mac
First you should be replacing the positive wire to the HEI with 10 awg wire, minimum 12 awg. The HEI requires a full 12v to coil. This has been discussed many times.
Second assuming this is not a Pertronix, or external coil, it is marked on the distributor cap Tach and Bat.
Larry
I don't own a vehicle that isn't old enough to drink.
LGriffin #623189 02/24/2010 10:56 PM
You are obviously talking about a external coil HEI.
https://www.stovebolt.com/ubbthread...mp;Number=612994&nt=2&page=1That
should have everything you need to know (and some you don't, Ha ).
'67 GMC 3/4 292 4spd
Thanks!!
