1 members (1 invisible),
56
Mod | | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 45 New Guy | | New Guy Joined: Feb 2010 Posts: 45 | Hi,I was wondering if someone might be able to give me advice on where to hook up a hoist to pull 235 6cyl.engine? I have yanked plenty of v8s but not sure about a 6cyl. A person in a local area has offered to sell his 235 and 3spd tranny at a good price if I will pull it for him since he does not have the tools, But I was wondering where to hook it up and is it best to use a chain or heavy duty straps?
Thanks for any info. | | | | | Joined: Feb 2010 Posts: 45 New Guy | | New Guy Joined: Feb 2010 Posts: 45 | Thanks for the info.
Gene | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Use a chain, like the method that tclederman posted the link for.
58' 3200 235 3-speed/OD
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I've always ran a good chain diagonal from a manifold bolt rear left side across to a bolt water pump hole on the right. I would use the adjustable gizmo that allows you to turn a crank and adjust weight and position of the motor. | | | | | Joined: Feb 2010 Posts: 45 New Guy | | New Guy Joined: Feb 2010 Posts: 45 | Thank you all for the good info, I have all those tools just did not know where to hook up after looking at those old six bangers I never realized how big and heavy those things are.
Thanks Gene | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I took out the radiator and grill, and pulled it right through the front of the truck. Easy peasy, lemon squeezy.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | A good safe way to pull that engine is go to Ace hardware or some place like that and get two eye bolts the same size as your head bolts and take two head bolts out and replace with them with them thats the way I have been duing it I also built a chain spaner above the engine out of a pc.of 1 1/2 angle iron it will keep the engine in control and the eye bolts are rated at around 1200 pounds each so it is real safe.
Pete | | | | | Joined: Aug 2005 Posts: 94 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 94 | I use an Eastwood engine leveler with the four "L" saped brackets and 1/2-13 bolts in place of four head bolts.
Joe D. | | | | | Joined: Feb 2010 Posts: 45 New Guy | | New Guy Joined: Feb 2010 Posts: 45 | Those are all great ideas guys.
Thanks for the info. | | | | | Joined: Oct 2007 Posts: 84 New Guy | | New Guy Joined: Oct 2007 Posts: 84 | Do not use the valve cover bolt holes. They can and will break out from the head! I won't tell you how I found out back in 1966. dgerth | | |
