9 members (wilbur53, Otto Skorzeny, Greg_H, 68ironhead, WICruiser, Gdads51, Shade Baby, rinemb, 1 invisible),
243
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,075 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | Hello All -
My '62 has no heater at all. I need to know what parts I need to get one installed. I know I need a heater core...how does that bolt up to the firewall? I know I need a blower...how does that install in the cab? What parts am I missing? Please advise. Thank you!
Thom Masterson
| | | | | Joined: Oct 2005 Posts: 116 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 116 | I can't say for sure about a '62 because my truck is a '65 model . On it , there is a large box , under the hood , on the passenger side firewall . This box contains the heater core and the blower motor mounts on the bottom side of this box ( accessible from the under hood area ) .The corresponding duct work connects to it ( inside the cab )under the dash .The heater controls vary depending on the model truck you have .If you go to www.lmctrucks.com , there should be a diagram showing the layout of it all .If you need an actual picture ( view ) of the heater box , check any engine compartment photos on the site or a similar site .Good luck !
" The heart of the wise inclines to the right , but the heart of the fool to the left " - Ecclesiastes 10:2
| | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | Whenever I ask something on this site, I always get tons of help. Thank you so much for your replies. They really helped alot.
Thom Masterson
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | I would also like to agree with Mark's advice. The 60-62 economy or recirculating heater would be the simplest to both acquire and install. Only 2 cables are needed instead of the deluxe heaters' levers/cables/switch. There are lots of guys who will rip out the complete system in order to throw in an aftermarket AC system. So be on the lookout on Craigslist (through Jaxed.com) as well as eBay for that stuff. Be patient and you'll end up with exactly what you need for a reasonable price. The econmy setup doesn't enter into the engine bay like the deluxe does, so that's a plus as well. Good luck | | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | Great advice. Thank you so much.
Thom Masterson
| | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | got one of the economy heaters, no rust, never used it so cant asay if core leaks but no staining inside!
Don Thela | | |
