8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible),
67
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,014 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Rebuilt the 350 in my '57 3/4 ton and had new exhaust done. The guy sold me on a pair of "Chrysler Hemi" mufflers. They are big and he said they would be quiet but not too restrictive. Dual with a crossover pipe and ended them just in front of the rear end (hydraulics for the dump bed make it a little challenging). They have a funny tinny sound out the tail but in the cab they seem to have developed a low frequency hum that resonates so bad, it's like a really bad toothache. Wondering if it's the mufflers or the fact that I didn't run the pipes all the way back? (He did say I can come back if I don't like them.)Any exhaust experts out there? | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Have mine the same as avetteforme and no problems with sound. i do have my cab floor insulated very well. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Cab is insulated with Dynamat, padding and carpet. Must be those weird mufflers. | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Harmonic resonating? Might try to insulate the cab. | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Put a set of mid-70's Cadillac mufflers on it. They're 2 1/2" diameter, inlet and outlet, and one muffler is sized to flow up to a 500 cubic inch engine. A set of duals with those pipes and mufflers will handle a 350 at any RPM you want to run with flow to spare. They're quiet, too! Jerry
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Change the mounting points on the mufflers, or add some. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You might need rubber hangers. Most muffler shops hook the system up with metal brackets directly or use plastic bushings. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | With them exiting under the bed, you have turned the bed into a sounding board. The exhaust needs to exit past the rear axle out the side, or past the bumper to not resonate under the bed.
As for making a really quiet system, tie the two sides together into a 3" resonator, then use a 3" in, and dual 2.5" outlet muffler if you want dual exhaust tips, or a 3" in / 3" out if you want a single exhaust system.
| | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Yes. Those last three posts resonate. I think you are going to be right about the hangers and the bed acting as a sounding board. It didn't do that before with short mufflers that exited out from the frame behind the cab. And they used rubber strap hangers instead of the more solid ones employed now. Once again, I should have talked to you guys BEFORE I pulled the trigger...doh! | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Mine do that too with Dynomax Superturbo mufflers. They're quieter at idle but boom really bad at any kind of driving speed. My solution will be to switch to Flowmaster 50 series mufflers and insulate the heck out of the cab.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Went back and had him put on quiet mufflers like I asked for in the first place. Helped alot but I'm guessing that until I move the pipes aft of the rear end it's always going to resonate inside the cab at idle. I'm getting used to it. But then again, you can get used to hanging if you hang long enough... | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | Did you turn them down or do they run straight? | | |
