4 members (49nut, Steelonsteel, klhansen, Shardean), 73 guests, and 4 robots.
Topics128,022
Posts1,055,376
Members48,420
#622618 02/23/2010 1:25 AM
jdl
Offline
Just got a '67 Chevy with a 283 and three speed(converted to floor shift) that's in remarkably good shape for being 43 years old. The only problem is that the speedometer doesn't work. I'm guessing since the odometer isn't turning either that it isn't hooked up or the cable is broke, but it could be the speedometer itself, I guess. Any ideas on how to see what is wrong???
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #622639 02/23/2010 2:36 AM
Check the speedometer cable. Is it attached at both ends? If not take it loose at the speedometer end and see if it turns freely. If it does you probably have a broken cable.
jdl
Offline
How would I do that??? I've never went down this road before so... It'd be easier to take it off at the transmission wouldn't it? I don't want to take the dash apart for nothing because after all my mom did just by it. Thanks for the help! smile
Jordan D. Long
Photobucket
jdl #622668 02/23/2010 3:45 AM
easy check: take the cable loose from the speedo [just reach up behind the gauge set, a big finger tight knurl knob] - drive the truck and check the top end hanging at yer knee to see if it's turning - if it is, the speedo needs work, if not then it's likely a bad cable, next step is to pull the inner cable out of the housing from the top, if it's all there with the correct shaped ends, the drive gear in the trans is most likely the problem, if it's broke/gummy/twisted up, replacements are easily available
jdl
Offline
How much would any of the culprits cost? Not over a $100 I imagine(hopefully).
Jordan D. Long
Photobucket
jdl #622748 02/23/2010 2:08 PM
Speedo cable at auto zone between 10 and 20 dollars depending on length.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
jdl
Offline
Thanks Ron and all of the rest of you. I popped the cable off and I noticed that I hit the thing that spins the needle and it moved, so it is narrowed down to the cable and the gear in the tranny.
Jordan D. Long
Photobucket
jdl #622887 02/23/2010 11:54 PM
jdl
Offline
Speedometer cable was broke off by the tranny. Thanks for the help guys.
Jordan D. Long
Photobucket
