3 members (TooMany2count, RoadsScholar, 1 invisible), 122 guests, and 3 robots.
Topics128,100
Posts1,056,514
Members48,448
#622160 02/21/2010 5:42 PM
were do i get the seals for the transmission and the tube. dont' know if I need them but would like to be able to get them.
is there a seal behind the tranny going to the torque tube. I've heard that they can go bad and then leak the fluid into your differential.
You'll need this type of set for the ball/cover and seal. It is similar to the Fel-Pro Universal Joint Set (part # ES 72843).
The seal that keeps fluid from running back into the rear-end is a seal inside the torque-tube. This "Okie Bushing" is a commonly used replacement (a replacement bushing and seal).
