7 members (FAST55, 2-Ton, Reftys49, Eisenholtz, MickeyP, Oswald, Ponchogl),
117
Mod | | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 36 New Guy | | New Guy Joined: May 2008 Posts: 36 | Hello. I need some suggestions for a reliable source for a rebuilt carb. I have a '54 235 with a carter YF 2100S that is in need of rebuilding or replacing. Ive purchased two rebuild kits so far. The first being for a Rochester, my error here. And the second for the Carter but this one won't work because the brass float valve body is significantly taller than the original making the float impossible to adjust. I'm giving up and looking for a remanufactured one instead. Does anyone have a recommendation? Is the Carter really much better than the original Rochester? The only modifications have been 12 volts and an electronic ignition. Thanks
Josh '54 3600
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | JBTrue, Call the Carburator Shop. The owner, Jon, is CarbKing on this site He provides superior kits and can give you advice. http://www.thecarburetorshop.com/Kent | | | | | Joined: May 2008 Posts: 36 New Guy | | New Guy Joined: May 2008 Posts: 36 | Thanks, No rebuilt in stock but I was able to order a rebuild kit that by description sounds to be correct.
Josh '54 3600
