1 members (delky),
127
Mod | | | Forums66 Topics128,193 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62160 06/25/2006 2:19 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | We went to look at a 1941 216cid engine last weekend. The doctor is in favor of returning his 41 to origional condition. It now has a 56 235. The 216 runs without any abnormal noise. The plan is to take the 216 straight to my old machinest guy to have him swap out the cast iron pistons and babbit rods with insert rods and aluminum pistons. What I need is a info on paint for the block and heads. I could realy use some pictures of the engine as it was in 1941. Also the 216 has floor mount starter pedal, did this truck ever have a floor mount starter pedal?
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
#62161 06/25/2006 2:50 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Jim Carter's sells the engine paint. It is called gray but it has a lot of blue in it. This is what it looks like on the engine. As far as the floor starter, everything had a floor starter up until 54(?) | | |
#62162 06/25/2006 5:41 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | '59 on 6 cylinder manual transmission in trucks, passenger cars changed to key start in '49.
Bill Burmeister | | |
#62163 06/26/2006 12:42 AM | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Are you sure you don't work for Earl Shibe (sp?) they don't mask anything off either.
#62164 06/26/2006 4:03 AM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Cool on the paint and the starter. The engine pick is great 46 but I think tiny is right. lol Earl would be proud. lol All kidding aside ty for the pic. Anyone else have pics of a complete origional engine from 1941? I want to see fuel pump, sedement bowl (if app.) the way the fuel lines ran. You know all the stuff that makes it a 41. Actually I am thinking of buing a chevy truck restore book, just for the pics.
#62165 06/26/2006 5:17 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The original paint was a much darker gray. My 33 is painted the same color as the picture, but it is wrong. The Filling Station in Lebanon, Oregon and Chevs of the Forties are the only places I know of that have the correct color. Check the VCCA site; they are really into correct restorations. | | |
#62166 06/26/2006 5:41 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | In 1941, they didn't have any sort of filter on a "stock" configuration. There were optional add-on sediment bulb style filters that were either attached to the carb or a metal fuel line was cut so that the filter was behind the horn and over the manifolds. And yes, the 6v starter for trucks was always a foot start. Makes it harder for people to take off with your truck. Starters and generators, IIRC, should be black. | | |
#62167 06/27/2006 5:39 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Are you sure you don't work for Earl Shibe (sp?) they don't mask anything off either. All the masking is still in place in the pic...As far as plugs go, I figured new paint was a good excuse for new plugs....I masked off the number stamp site, the fuel pump mount, dizzy hole etc...the paint was about 10 mins old in the pic..the fan, etc will be pulled and painted later.... | | |
#62168 06/29/2006 4:59 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Thanks guys, I have a newer post on the progress of the 216. An thanks to all that posted. James
#62169 06/29/2006 7:04 PM | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Shouldn't it be more like this COLOR ? | | |
#62170 06/29/2006 8:48 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | AD_Pickup, Look closly at the fit of your fan on your water pump when you install it. Your water pump has one of the replacment cast pulleys I have been seeing lately that has the hub turned down to small.
I just installed one of these, I rapped the hub with thin card board to center the fan while it was tightened.
See the USA in your vintage Chevrolet! My Blog | | |
#62171 06/29/2006 9:58 PM | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Pre '68 Dave, the fan has has been on that pulley for over two years and it was a snug (not a good pic) fit over the hub. This is a 1953 216 original engine, fan and as far as I know the original pulley. When I got the truck (2002) the last registration sticker on the plates was 1977. I wouldn't think it would have had a replacement pulley. | | |
#62172 06/29/2006 10:33 PM | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Originally posted by 46 In Progress: All the masking is still in place in the pic...As far as plugs go, I figured new paint was a good excuse for new plugs....I masked off the number stamp site, the fuel pump mount, dizzy hole etc...the paint was about 10 mins old in the pic..the fan, etc will be pulled and painted later.... Not trying to rattle you chain 46, just messing with you although I've never seen painted acorn nuts & washers.
#62173 07/01/2006 1:51 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | AD? The intake manifold was the same color? How about the oil filler tube and the bell housing? I did an engine on a 54 vette (blue flame) it looked like the one 46 posted. Rut Row scoobie! Me thinks I now have differing opinions. HUMMMMMMMMMMM?!?!
#62174 07/01/2006 3:43 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Toyvo,
All I did is order the paint from Jim Carter and spray it on...if it is the wrong color, I would be bummed out. But not bummed out enough to start over and repaint.
Oil filler tube was black. Mine still had a pile of black paint on it.
Bell housing...if you check the suppliers, many sell a cast iron black for the tranny and bell housing...I did mine in black. | | |
#62175 07/01/2006 4:31 PM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | The entire engine "proper" was painted dark gray. Acorn nuts, both manifolds, gasket edges, oil filler cap on post '48's, bellhousing, dipstick, even the bracket from the water pump to generator. The whole shebang was assembled before painting.
Black items include the draft tube, distributor, coil, fan blade, generator, starter, foot starter assembly, and I'm probably forgetting something off the top of my head. "Thriftmaster" was also painted on the valve cover in yellow with a stencil, not the decal like the vendors sell.
Although you'll get disagreements, the 4-speed tranny in my '51 was painted black. It had some factory inspection marks that were on top of what was left of the paint.
Granted the paint wore or burned off some of these items pretty quickly, like the exhaust manifold, gasket edges, and acorn nuts.
Bob | | |
#62176 07/02/2006 2:39 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Thanks Bob, But is the dark gray like 46 shows or more like what AD shows?
#62177 07/02/2006 7:19 PM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | It's more like 46's. It's a pretty dark bluish gray. The Filling Station and Chev's of the 40's carry the correct color. The gray from Bill Hirsch and some other vendors is too light. I had my local paint jobber match the color to an NOS timing gear cover I had.
Bob | | |
#62178 07/03/2006 5:10 AM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Thanks Bob, here are some pics, enjoy my link
