0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 15 New Guy | | New Guy Joined: Dec 2007 Posts: 15 | The bolts that hold the throttle butterfly to the respective shaft (when using replacement parts) may be held in place by using some locking compound (e.g., Loctite), or is it mandatory to deform its tips? Many thanks for any help. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Usually they are brass screws and can be easily deformed with a punch to keep them from threading back out.
Drew
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think our carb expert stated that they use locktite in a post a while ago. | | | | | Joined: Dec 2007 Posts: 15 New Guy | | New Guy Joined: Dec 2007 Posts: 15 | Many thanks, Drew. Truckernix, I guess I'll follow the easiest way (Loctite). By searching "loctite", I found two posts from Carbking (page 2, 25 Feb. 2009 and page 3, 17 Jul.2008 and another from Cavebull (page 3, 17 Jul 2008), all three endorsing the use of the adhesive. Thank you for the valuable advice.
Fabio. | | |
