5 members (Gdads51, papas52, Bruce 1954-4100, tclederman, Forty9), 102 guests, and 0 robots.
Topics128,110
Posts1,056,257
Members48,437
#621195 02/18/2010 6:35 PM
The bolts that hold the throttle butterfly to the respective shaft (when using replacement parts) may be held in place by using some locking compound (e.g., Loctite), or is it mandatory to deform its tips? Many thanks for any help.
Usually they are brass screws and can be easily deformed with a punch to keep them from threading back out.
Drew
I think our carb expert stated that they use locktite in a post a while ago.
1951 1 Ton Completed
Many thanks, Drew. Truckernix, I guess I'll follow the easiest way (Loctite). By searching "loctite", I found two posts from Carbking (page 2, 25 Feb. 2009 and page 3, 17 Jul.2008 and another from Cavebull (page 3, 17 Jul 2008), all three endorsing the use of the adhesive. Thank you for the valuable advice.
Fabio.
