8 members (Rustnut, Otto Skorzeny, Gib70, Bisbee, Southerntruck, Gdads51, greenie-reddy, 1 invisible),
97
Mod | | | Forums66 Topics128,079 Posts1,056,300 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 12 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 12 | I have a 1954 chevy 235 thats bored 60 over. I plan on putting a dual carb intake and fenton headers on the engine. I was thinking about getting a Howard's performance grind cam Patrick's and just want to hear thoughts from others on what might be a better choice or cheaper. Also, a regrind probably isn't going to work as my cam has some bad pitting on the lobes.
Thanks for your help, Thomas. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I've got an M4F Howard cam from Patrick's in mine, and am very happy with it. This is what mine sounds like.
Bill Burmeister | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | I went with Clay Smith Cams. They did a custom grind for $200 or a little more. I told them what I had and the specs of different thing(they have a questionar you fill out) and tell them what you want, low end torque ect... and the grind it to specs.
58' 3200 235 3-speed/OD
| | | | | Joined: Jul 2005 Posts: 9 New Guy | | New Guy Joined: Jul 2005 Posts: 9 | Apache Friend, What lift and duration did you go with? I'm looking at getting a clay smith and with my setup, he's recommended a .525 lift with 276 duration. Here's what i'm running: three carter singles through an offenhauser intake dual exhaust into 2" pipes with smithy's mufflers 235 cu. bored .030 over milled head, maybe .020
Any advice? | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | themmer...I have the 3/4 race cam from Patrick's and I wouldn't buy it again. Please understand that it always comes down to what one expects and wants. Mine is just too rough for my taste which is for a lot of power but a good idle factor which is what I don't have. Patrick Dykes is a great guy however and I would not hesitate to do business with him. I have no idea of the particular spec's but don't care anyway as I am not that profound as an engine builder. I think one should always go with the expert recommendations IF they understand what you want and expect.
And remember Jackson these are I-6's not V8's so don't get caught up in the big cam game as it's another set of rules. | | |
