0 members (),
107
Mod | | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62142 06/25/2006 4:38 AM | Joined: Dec 2003 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 62 | My 51' 1/2 ton has 15" wheels on it. The rims are period, but if I read my Chevrolet manual correctly, I think the truck came with 16" wheels, larger trucks had 17", there was one model shown that came with 15", but it was not a pickup. Before I purchase new tires, I want to have the right size rims, 16's? Thanks! | | |
#62143 06/25/2006 4:43 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 16's would be correct for your 1/2 ton, the 15' option you saw was for 3/4 ton. Personally, if the 15's look right and if you are not worried about 100% originality, I'd stay with them. There is a larger variety of tires in 15".
Bill Burmeister | | |
#62144 06/25/2006 4:43 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | You are correct.
Your truck should have been equipped with 16" rims. However, IINM, the 15" was an option that could be ordered. | | |
#62145 06/25/2006 12:41 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 15" (6 lug) wheels and tires were an option (not common, though) on 1/2 ton trucks in 1951.
The 15" wheels commonly used on 3/4 ton trucks were different wheels. Maybe someone else can confirm if 1/2 ton and 3/4 ton wheels had a different number of wheel lugs. | | |
#62146 06/25/2006 8:44 PM | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 |
-Tom
1950 Chevy 3100 w/ 1956 235
#62147 06/25/2006 9:01 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Originally posted by tclederman: 15" (6 lug) wheels and tires were an option (not common, though) on 1/2 ton trucks in 1951.
The 15" wheels commonly used on 3/4 ton trucks were different wheels. Maybe someone else can confirm if 1/2 ton and 3/4 ton wheels had a different number of wheel lugs. The 3/4 ton '47 on up have 8 lug wheels. I have seen the 8 lug 15" wheels, they are some what odd looking due to being such a small size, especially copared to a modern 3/4 ton. Those 15" rims will not fit on a disk brake 3/4 ton truck, they hit the calipers. I've seen guys grind the calipers off to make them fit, but this is not a safe procedure as it weakens the casting.
#62148 06/26/2006 2:56 AM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Those 15 inchers are quite rare, since they were an option back then. It is interesting to note that GM only considered the truck capable of carrying the maximum GVW when it was equiped with the 15 inch rims. | | |
#62149 06/26/2006 4:10 AM | Joined: Dec 2003 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 62 | Wow! You all are great! I can see that my gvw of 4800, should have had 16" rims. I do think it looks better with the 15's, but I wonder since I will be driving with the stock rear & 3 spd. for a while, would I be better off with the 16", more accurate with the speedometer? or just leave well enough alone? If I go with the 16" rims, would 235x85 16's be too large? I think the width would be o.k.? Thanks Again!!! | | |
#62150 06/26/2006 5:48 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Originally posted by LONGBOX55: The 3/4 ton '47 on up have 8 lug wheels. I have seen the 8 lug 15" wheels, they are some what odd looking due to being such a small size, especially copared to a modern 3/4 ton. 3/4 tons had 15" wheels dating back through the forties -- probably earlier -- and 1946 was the earliest year for the 8 lug set up. | | |
