| | | Forums66 Topics128,049 Posts1,055,649 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 11 New Guy | | New Guy Joined: Feb 2009 Posts: 11 | i have a 66 c20 that had a 250 straight 6 w/3 speed man and i want to put a 350 w/ automatic in it. what do i need for motor mounts? is there a motor mount that will use my exhisting frame mounts? | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | just bolt it in.where the frame perches go there are 3 holes of which they use 2. the stock 6 cyl location is the frt 2 and the v8 uses the rear 2. you will have to remove the rear eng crossmember(under the bellhousing and install a rear trans crossmember in ron | | | | | Joined: Feb 2009 Posts: 11 New Guy | | New Guy Joined: Feb 2009 Posts: 11 | the bracket that bolted to the 6 cyl. block is a different bolt pattern than my 350. i dont see how your reply will work. are you saying a v8 motor mount will bolt to the front suspension crossmember instead of the old style mount?
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | you just eliminate the brkt between the insulator and the block on the I6. the insulator will bolt to the v8 block. look at it znd you will see. think ron | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | Yes...I-6 is much narrower than V-8. Your clutch pivot has an extra "spacer" for the same reason. Best Luck.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The factory engine perches for the straight six, have an extension piece that makes up the difference between the engine mouting surface of the factory V8 engine perches and the six cylinder...remove this extension and the V8 motor mounts will bolt to the engine perch and the V8 will nest on them and bolt up. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | that poor old c20 will just feel like everybody else with a 350/auto. | | | | | Joined: Feb 2009 Posts: 11 New Guy | | New Guy Joined: Feb 2009 Posts: 11 | i called napa and got new insulators for 7 bucks each and once i saw them and thought about it it all made sense. i must have had one of those old guy moments going on. it happens!!thanks for all the help. | | |
