5 members (walter74, Ponchogl, moparguy, 55shaker, 1 invisible), 147 guests, and 7 robots.
Topics128,089
Posts1,056,138
Members48,435
I have a 1936 high cab 1/2 ton pickup.
does anyone have information on the correct rear cab mounting. The rear of the cab supports the roof and is attached to a wooded frame that is mounted to a 1 inch thick board that is suppose to float on the frame using rubber spacer, spring and bolt.
Any information would be appreciated.
Charlie
Apprentice
Apprentice
This link may contain your info. I like this site and use it a lot
http://chevy.oldcarmanualproject.com/chevyresto/37index.htm
You cannot measure a man by where he sits in comfort and security, but where he stands in times of adversity and danger.
Jim Carter catalogue seems to have the replacement springs and stuff. It is kind of hidden with no pictures, but I believe under cab mounts. i used my old stuff for now. I think the springs basicly hold down the wooden parts to the wood block and frame. The spring keeps the cab from flopping upward and yet allows it to twist too.
Thanks for the information, I think that that will solve the mystery.
Charlie
