1 members (3800GUY),
89
0
Mod | | | Forums66 Topics128,189 Posts1,057,336 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | i have a 1952 1/2ton and i am goint to install a 1957 235 out of a car. which clutch size shouls i use. i am going to keep my 3spd column shift. i also have a 1951 1/2ton with a 1955 235 that needs clutch replaced 3spd also. thanks Paul | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Use the size that goes with the flywheel you are useing. On the 51 use a replacement for the clutch that is in there. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | does it matter which bell housing i use? classic truck parts have two they say will fit one is 9 1/8 inch one is 10 1/2. they say both will fit. is one better than the other. thanks Paul | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | both will fit in the truck bellhousings, just depends what your flywheel is drilled for. | | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | you should have no problem with the original clutch size (10") as a 235 was an optional motor/direct bolt in. the bigger 11" clutch is a big bolt clutch. I asked the same question regarding my 46 which i am dropping in a 261. most opinions were even in that combination the 10" would hold for an every day driver. i went with the 11" just to be a little over the top w/ the 261.
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
| | | | | Joined: Mar 2009 Posts: 40 Apprentice | | Apprentice Joined: Mar 2009 Posts: 40 | I have a 55' 235 out of a car that I put a t-5 behind . The truck ( 1962 c-10 ) had a 3 speed from a 57 truck that was working well so I just replaced the clutch disc . there are many clutch discs that will fit as the splines of the old 3 speed and the t-5 are the same , but the 83-84 firebird clutch disc was the larger ( 9-9/16 ) and the cheapest . It was less than 30 bucks at auto zone ! I put this package together about 2 months ago and I drive the truck every day , Its working great ! Good luck . | | |
