| | | Forums66 Topics128,088 Posts1,056,124 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | I just got a 1949 Olds for parts (with a 303 Rocket V8) and believe it or not, the radiator it the same size. the top outlet it about 2" offset, which should be fine with a flexible hose. but here's the good parts: first, it's 2-1/2" thick, versus 2" for my truck radiator second: it has a shroud! I do need to use the Olds fan as well to fit the shroud. so one of these weeks, before summer starts (which will be in a month, here in AL) I will install my 1949 Oldsmobile "desert cooler special" package. I am going to run so cool, it'll be great! | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Just make sure the radiator is clean and remember it may not hold the pressure of a modern engine. | | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | I'll flush it. I'm sure it'll hold the pressure. I mean, 303 CI V8 from 1949 versus a 235 CI L6 from 1959? the Rocket probably has more pressure than the Stovebolt | | |
