4 members (Bucker, Nick in Manitou, Shaffer's1950, 1 invisible), 220 guests, and 2 robots.
Topics128,189
Posts1,057,337
Members48,469
#620125 02/15/2010 1:49 PM
i have a 1952 1/2ton and i am goint to install a 1957 235 out of a car. which clutch size shouls i use. i am going to keep my 3spd column shift. i also have a 1951 1/2ton with a 1955 235 that needs clutch replaced 3spd also.
thanks Paul
wodniw5 #620138 02/15/2010 2:38 PM
Riding in the Passing Lane
Use the size that goes with the flywheel you are useing. On the 51 use a replacement for the clutch that is in there.
1972 Chevy c10 Cheyenne Super
does it matter which bell housing i use? classic truck parts have two they say will fit one is 9 1/8 inch one is 10 1/2. they say both will fit. is one better than the other.
thanks Paul
wodniw5 #620430 02/16/2010 4:37 AM
both will fit in the truck bellhousings, just depends what your flywheel is drilled for.
you should have no problem with the original clutch size (10") as a 235 was an optional motor/direct bolt in. the bigger 11" clutch is a big bolt clutch. I asked the same question regarding my 46 which i am dropping in a 261. most opinions were even in that combination the 10" would hold for an every day driver. i went with the 11" just to be a little over the top w/ the 261.
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
bigedpa #620821 02/17/2010 2:49 PM
Apprentice
Apprentice
I have a 55' 235 out of a car that I put a t-5 behind . The truck ( 1962 c-10 ) had a 3 speed from a 57 truck that was working well so I just replaced the clutch disc . there are many clutch discs that will fit as the splines of the old 3 speed and the t-5 are the same , but the 83-84 firebird clutch disc was the larger ( 9-9/16 ) and the cheapest . It was less than 30 bucks at auto zone ! I put this package together about 2 months ago and I drive the truck every day , Its working great ! Good luck .
