4 members (52Carl, Bill Hanlon, 2 invisible),
172
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,190 Posts1,057,342 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 9 New Guy | | New Guy Joined: Feb 2010 Posts: 9 | sorry iam new to all of this but could someone call me and talk to me about doing this swap .Ive read on lots of palces about doing this , but would like to talk to someone. thanks Scott Potter 417-262-1466 | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Your best bet is to submit your concerns and questions here Scott. That way everyone can see them and you'll get better and more advice. Yes, I know sometimes you can also just get opinions and too many of them but really there are a lot of very sharp individuals on here who can steer you along. That is why this place exists and how it works.
So please just submit the questions and we'll get you started. And WELCOME to the Stovebolt page. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Scott,
Dave's advice is, as usual, very good.
Post the following information and you'll get helpful replies.
1. Year of your truck. 2. Year of the 216 engine. 3. Year of the 235 engine (and, if came from a car or a truck). 4. Transmission/rear-end in your truck: is it original to the year of the truck; otherwise, give year/type information.
| | | | | Joined: Feb 2010 Posts: 9 New Guy | | New Guy Joined: Feb 2010 Posts: 9 | thanks for the invite! iam not sure of eveything on years. the truck iam putting it it is a 1938 firetruck 6v system with i beleive a 3 speed on the floor,idue know you have to pull the lever on the gear shift to go into reverse. the 235 that i have has the bolts around the battom of the cover, i think its from a car(notsure). i would like to couple it to my trans to keep it somewhat orginal looking. Ive read about the front cover change and the bolts by the dampner pully that is used for engine mounts. not sure about the bell houseing and the rest. as far as making something thats ok for me to due | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think that you will use everything from the engine block back, from the 216. You can use the two studs that hold the 216 valve cover on to mount it on the 235 and then it looks almost identical. Also, with one of Pre68 Dave's water pump adapters, you can use the 216 water pump and have no clearance issues at all. | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | The swap you're thinking about is almost a bolt in deal. If your late 235 is 55 or later be sure and save the bell crank and linkage for the blab petal. You may want to think about the exhaust manifold as the really early 216's dumped a little different than the later 235's. As for the bolt holes under the damper they can be drilled befor installing the motor. | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Not sure about '38 but for '41-46 if the transmission has a lever for reverse it's usually a 4 speed non-synchronized.
Harold Wilson 41 Chevy 3/4 Ton
