| | | Forums66 Topics128,154 Posts1,056,863 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61876 06/18/2006 4:15 AM | Joined: Jun 2005 Posts: 7 Junior Member | | Junior Member Joined: Jun 2005 Posts: 7 | Well, I drove my C-10 over to my buddy Jack’s (the guy that built the engine in the Valiant) and we tried to figure out a weird problem… The truck seems to stall, especially at freeway speeds. It kinda feels like it’s running out of gas.
- It has gas. - It has good spark, I replaced the coil, the points, the condenser, the cap and rotor.. the cables seem good and so do the spark plugs. - It’s getting fuel, I replaced the fuel pump and installed a clear filter – no junk in the gas. - It has a new air filter - We tested the compression, not awesome… but acceptable: average of about 135 each. - We ran a leakdown test on Cylinder 1 (the one with the worst compression: 110)– seemed OK - It has a new alternator (that I got from a friend) - I even squirted a bunch of gasoline into my eye for good measure while changing the fuel pump. History on the truck: 1969 C-10, 250 inline 6, 3 speed Borg Warner overdrive (the overdrive is not hooked up and it’s not attached to the carb). The truck is pretty beat down..
I have had the entire truck re-wired, and it has had the clutch and breaks fixed up. The engine is all stock except for the extra junk for the overdrive, but none of the overdrive solenoids are wired.
I think that my next step is to replace the carb. It’s a Rochester Monojet. I found one for $125.00 (wholesale price at Worldwide Auto Parts).
Plugs and wires?? I have no clue.
Joe Poutous
Stupid like a fox.
#61878 06/18/2006 5:00 AM | Joined: Jun 2005 Posts: 7 Junior Member | | Junior Member Joined: Jun 2005 Posts: 7 | Originally posted by TooMany2count: check the float height, could be set to low & it's simply running out of gas....joe That sounds like a good place to look next... I was just talking to my Dad (Father's Day is tomorrow!) on the phone and he said the same thing, that maybe the floats needed adjustment or that there was a pinhole... Thanks for the Reply! - Joe
Stupid like a fox.
#61879 06/18/2006 7:17 AM | Joined: Apr 2006 Posts: 53 Member | | Member Joined: Apr 2006 Posts: 53 | My 69 C-10 did the same thing it would cut out on me at freeway speeds. Turns out the shop that installed my reman 250 (from ATK ugh! tahts another story)installed the inline fuel filter in backwards. Once I flipped it around it ran ok | | |
#61880 06/18/2006 3:46 PM | Joined: Jun 2005 Posts: 7 Junior Member | | Junior Member Joined: Jun 2005 Posts: 7 | Originally posted by Legman292: My 69 C-10 did the same thing it would cut out on me at freeway speeds. Turns out the shop that installed my reman 250 (from ATK ugh! tahts another story)installed the inline fuel filter in backwards. Once I flipped it around it ran ok That's a good one! It would be a real drag if the fuel filter was backwards, I installed it. - Joe
Stupid like a fox.
#61881 06/18/2006 7:50 PM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | Lean surge maybe? If the filter is not flowing properly, or the carb isn't providing enough fuel into the mixture at part throttle, you can get a surge...it'll kinda stall then jump ahead, then stall a bit and so on. On other types of carbs I've fixed this by going to the next richer jets. | | |
#61882 06/19/2006 2:42 AM | Joined: Jun 2005 Posts: 7 Junior Member | | Junior Member Joined: Jun 2005 Posts: 7 | So.. I drove down and filled the tank, even though I had a few gallons left (gas was sloshing, the gas gauge does not work)... On a full tank it runs great. That means that the pickup tube is messed up, or that there is crap in the tank. I have a new sending unit that should solve most of the problem, but if I don't get the tank cleaned the problem will come back.
- So it's off to the radiator shop to have it cleaned out.
thanks for all your input guys.
Stupid like a fox.
