5 members (Peggy M, Hush, MNSmith, Phak1, tclederman), 148 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
I have a 65 chevy C10 with a three speed shifter column and the steering wheel has quite a bit of play side to side. Also when I use the turn indicator arm the whole collar turs with it? Is there something that should keep the collar from moving so far? Does anyone have a diagram of the layout for the 3 speed column?
I believe there is a diagram of the 3 speed column on the LMC trucks site ( www.lmctrucks.com ). It should be helpful in your search . Is the play in the column itself or in the suspension components ? Have someone turn the steering wheel while you watch the steering shaft under the hood . Then get under the truck and have them turn the wheel back and forth . See if there is any noticeable looseness in any of the components ( idler arm , drag link , etc. ). This may help to figure out the problem . Good luck !
" The heart of the wise inclines to the right , but the heart of the fool to the left " - Ecclesiastes 10:2
I have the same problem with my '66--I'm actually in the middle of fixing it now. I found this http://s809.photobucket.com/albums/...action=view&current=IMG_1997copy.jpg after taking my steering wheel off.
Here's a post about the problem: https://www.stovebolt.com/ubbthread...;Main=87283&Number=612250#Post612250
Good luck!
Trey Wilkins
1950 Chevrolet 3100 Five Window
1954 Chevrolet 4100 Dumptruck (Sold)
1957 Chevrolet 6400 Dumptruck
1966 Chevrolet K20 Longbed Fleetside
1966 Chevrolet C60 Grain Truck (Sold)
More pix on Photobucket
I ran into the same problem when restoring the column in my 65 k10. I actually fashioned a bushing out of one of the parts that came when i ordered the lower bearing. this new bushing fit into the bottom of the lower collar centering the shaft. I am going for a 100% factory restoration; this however was unacceptable. the new bushing is awesome.
1965 Chevy Shortbed Fleetside
4 Wheel Drive K1445
More pix in Photobucket
