1 members (Samantha),
45
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Hi out there,
Another question from a first-time, older truck owner that is just feeling his way around a truck.
I need to bleed my brakes and need a few pointers as to how I start. What is the best way to do this? Is there a special kit I need to buy or can I do this using wrenches and a bottle?
I appreciate any insight.
Carlos | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | You didn't say why you need to bleed the brakes, but air in the lines is the usual reason that needs to be done. If you don't know how air got on there I would look for that first. If you feel like buying a vacuum pump you could use that method for bleeding the brakes. It just sucks the brake fluid out and instructions for using it would come with it.
The old way of bleeding brakes requires two people, one to pump up the brakes and the other to open the bleeder screw on the wheel cylinders. I usually attach a clear plastic line to the bleeder screw which lets you see the fluid coming out plus lets you run the fluid into a can which helps from making a mess. First make sure all bleeder screws will open, then fill the master cyl with fluid. The guy in the truck pumps the brakes, 3 or 4 good pumps and then holds pressure on the pedal. Yells to the guy under the truck, "I'm holding" Then the guy under the truck opens a bleeder screw for a short time to let some fluid out. When he has the bleeder screw closed he yells to the guy in the truck "Closed" The guy in the truck can not let pressure off the pedal until he hears that the line has been closed. Once the line is closed the guy in the truck can pump up the brakes again and repeat the procedure again. Do that at each wheel and the brake pedal should start to get harder. If it still feels spongy repeat the whole procedure again till all of the air is bled from the lines. Check the master cyl to make sure it does not run out of fluid. Don't be surprised if the person in the truck doing the pumping has a tired leg when you get done. I hope this helps you "get r done"
Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Thanks Glasman.
I bought the truck as a project in July. Getting ready to drop a new, working engine in it this week (old one was seized and had water in the block). I figure once I get it to run I need to make it stop.
I pushed down on the brake pedal and it went straight to the floor. I popped open the MC and added brake fluid. When I pushed down on the pedal again I saw the fluid "bubble" a bit and the brakes started to feel less spongy. I went back a week later and the brakes went back to the floor.
Does it sound like I need a new MC too, or should I try bleeding first and see what happens?
Thanks for helping a Newbie | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | If your brakes are old and unused for a few years, don't use a vacuum bleeder. Use the old-school method to bleed the brakes. If there is a leak or a bad cylinder, the vacuum bleeder will suck air into the system. This is a "Bad Thing". You'll think you are done, the go to press the pedal and... right to the floor. Using the pedal-pressure method you may see the leaks or see fluid drain down the backing plates (indicating a bad cylinder). Good luck and have fun!
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Just a reminder that a properly working and adjusted emergency brake is the most important safety equipment on your truck. Always nice to know that if you burst a line or wheel cylinder, and lose all pedal braking, that hand brake is there for you.
Good luck on the bleeding, AND the new engine. Sounds exciting!
-Michael | | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | fyi, my local flaps had bleeder screws called "speedy bleeders". basicaly a one-way valve. essentialy it lets one person bleed the brakes if you are short handed. you open the bleeder, you get in the cab press the pedal a few times, get out and re tighten the bleeder and move onto the next wheel. the small valve keeps air from entering the system when you release the pedal.
it worked well for me. | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Thanks monkey wrench for the Speed Bleeders suggestion... Just what I need... They can also be found at Napa
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
