2 members (pdlightning, Tronman), 104 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#61797 06/16/2006 1:18 AM
Junior Member
Junior Member
Hello Everyone,
I am heading out to a farm on Monday to look at a couple trucks for a posible rebuild. All are chevys ranging from 1947-1952. In talking with the farmer, he was unsure if the engines were original. I was wondering if there is any visual way to tell if the engine is an original 216 or pre 1954 235, or if it is later model straight 6 with full preasure oil system. Since I plan to use the truck regularly for work in the summer, a reliable engine would be preferable. Thanks for your help.
-Jason
#61798 06/16/2006 1:27 AM
A 216 and the low pressure 235 will have the tall side cover that surrounds the spark plugs.
Also the rocker arm cover will only have 2 studs through the top rather than 4 screws on the sides. A full pressure 235 is a bolt in replacement. Check Patrick's in the links page, there is more information on id for the early235 there.
Bill Burmeister
#61799 06/16/2006 1:29 AM
the 216s had a very tall side cover in relation to the later 235s. a 216 would have a valve cover with 2 nuts on top holding it down. a 228 to 302 gmc would also have 2 nuts holding the valve cover down, gmc would be stamped on the cover.
hope that helps a little
#61800 06/16/2006 1:52 AM
Serial numbers are a very easy way to tell.
If the number is three or four letters and then some numbers, then it's babbited.
If the number starts like this: GAA, ADCA, et cetera, then it's a 216 from one of the various different applications. the second to last letter will be "A", "B", or "C"
IIRC, if the second to last letter is a "D" or an "E", then chances are, you've got a 235.
There will be date code behind the starter.
Later Chevy 235 (full-pressure oiling) engines will have some numbers, then an "F" or a "T" two more numbers (the year code), and then an engine use code (usually a Z or a ZC or something like that). In 1958, they changed things up a little bit, and there isn't really a "serial number" on the engines, but there is a date code.
There is a tech tip on this website you can have a peek at that will give you some more information on the Chevy engines.
GMC engines will have the displacement (e.g. 228, 248, 302) first, which will tell you what the thing is. IIRC, all of the GMC engines from that era had insert bearings and were full pressure oilers.
#61801 06/16/2006 4:12 AM
sorry longbox55 looks like you beat me to it. If I could only type a little bit faster!
