5 members (Oswald, Brian Moore, crenwelge, Otto Skorzeny, 1 invisible), 134 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#617917 02/08/2010 5:48 AM
I know a 235 and 261 will cleanly swap into place where my 216 came out. What about a 292. Will I be able to bolt it right in without changing my 3 on the tree etc. I want to upgrade while keeping everything else original. Any thoughts.
nope , 292 has side mounts
Tommy
59 apache 1/2t
261 short stepside
Lode51 #617953 02/08/2010 12:10 PM
Virtually everything is different, bellhousing, clutch linkage, motor mounts, electrical system (12 volt), exhaust system, and you'll need a heavier-duty radiator to handle the extra heat load of nearly 100 extra cubic inches.
The swap you are considering is more difficult but it can be done. Another contributor on this board has done it. Try a search of 292 and see what hits you get. I even thought about this swap about a year ago. See here.
Professional Novice
The 292 will fit but with a lot of work. You need new motor mount brackets, move the radiator forward a few inches, clutch linkage, throttle linkage, and a bunch of small stuff, but it will be a great engine for your 51. With the right bell housing you will be able to use the stock rear engine mounts.
see photo link below
Jim & Caroline
1 Offline
Another option would be to find a 270 or 302 GMC. Still have to contend with some mods but not nearly as many as the 292 swap.
Caroline & Jim, that is one clean install of a 292 in a A-D pickup. Very Cool!!
Lode51, I am still thinking about the same swap. I move pretty slow tho, so you'll probably get yours done before I do. So take and post lots of pictures. Good luck. smile
Professional Novice
