| | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | I know a 235 and 261 will cleanly swap into place where my 216 came out. What about a 292. Will I be able to bolt it right in without changing my 3 on the tree etc. I want to upgrade while keeping everything else original. Any thoughts. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | nope , 292 has side mounts
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Virtually everything is different, bellhousing, clutch linkage, motor mounts, electrical system (12 volt), exhaust system, and you'll need a heavier-duty radiator to handle the extra heat load of nearly 100 extra cubic inches. Jerry
| | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | The swap you are considering is more difficult but it can be done. Another contributor on this board has done it. Try a search of 292 and see what hits you get. I even thought about this swap about a year ago. See here.
Professional Novice
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | The 292 will fit but with a lot of work. You need new motor mount brackets, move the radiator forward a few inches, clutch linkage, throttle linkage, and a bunch of small stuff, but it will be a great engine for your 51. With the right bell housing you will be able to use the stock rear engine mounts. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | see photo link below
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Feb 2010 Posts: 28 New Guy | | New Guy Joined: Feb 2010 Posts: 28 | Another option would be to find a 270 or 302 GMC. Still have to contend with some mods but not nearly as many as the 292 swap. | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Caroline & Jim, that is one clean install of a 292 in a A-D pickup. Very Cool!! Lode51, I am still thinking about the same swap. I move pretty slow tho, so you'll probably get yours done before I do. So take and post lots of pictures. Good luck.
Professional Novice
