6 members (klhansen, GRNHydra, Mike Roache, Maybellene, 6inarow, 1 invisible), 138 guests, and 2 robots.
Topics128,035
Posts1,055,552
Members48,425
#61791 06/15/2006 9:13 PM
Apprentice
Apprentice
So it sounds like i am going to have to swap out rear ends so that I can use a 250ci engine. Does anybody know what will fit fairly easily? I am not a master mechanic or fabricator. I was told that a late model Nissan Pathfinder would swap in pretty easy. Is that true? Any help would be great!!
#61792 06/15/2006 9:23 PM
If you want a simple and easy open drivetrain conversion get a 3rd member from a '55-'62 1/2 ton-it's a direct fit into your existing reaar end. Of coarse you will still have to fabricate engine/trans mounts for the 250 and whatever tranny you use.
Bill Burmeister
#61793 06/15/2006 9:24 PM
Apprentice
Apprentice
Were can I find the third member you mentioned?
#61794 06/15/2006 10:18 PM
Try the parts for sale forum, also EBAY. Salvage yards that have older vehicle should have them too. Most of them have a 3.90 gear.
Bill Burmeister
#61795 06/16/2006 3:10 AM
I guess I missed that conclusion in your other thread. Why do you have to swap years? You can make this swap using the stock transmission.
#61796 06/16/2006 4:14 AM
I did the same with a '60 3.90 rear. Real easy even for a beginner like me.
Steppenwood did it here.
Good Luck.
