4 members (walter74, baldeagle, kades51, 1955 1 Series), 65 guests, and 3 robots.
Topics128,014
Posts1,055,328
Members48,419
#61767 06/15/2006 9:25 AM
I was shopping around for plugs for my 70' 292. I usually go to Napa cause they have an old school parts guy named Rob. Stuff I ask for isn't in the computer so the parts guys have to go to the "book". I love it! So the book calls for AC R45's. I get home gap em and now they don't fit in the spark plug hole. The R45's are 13/16". The ones I pulled out were AC R44's which are 5/8". Am I going nuts? About half a dozen parts houses give the same plug size.
#61768 06/15/2006 12:05 PM
AC/Delco changed a whole lot of stuff around 2002 or 2003. One of the things that changed was the size of their spark plugs. I used AC exclusively for years and years. All of a sudden I started burning plug wires on the headers. Seems that the "current" R44TS and R45TS (the ones I was using in Chevy smallblocks) were longer and caused the plug boot to contact the header pipes.
I contacted AC/Delco customer support and the best answer I could get out of them was that it was my fault and their products worked fine. They never would admit to having changed the plug length.
So I made up this web page to illustrate the problems:
http://www.chevyasylum.com/acdelco/
Their oil filters changed, too.
The last time I got plugs for the 292 in my 64, I had to use Champions (not my first choice by a long shot, but they've been fine.) I've also had to put Champions in my Model A due to the lack of available alternatives.
As far as plugs for V8s, I've been using Bosch Supers and I'm happy with them.
Btw, I went to AutoZone to get the plugs for the 292.
Good luck with it.
#61769 06/15/2006 10:54 PM
Riding in the Passing Lane
You must have a latter head. Chev. changed the plug type back then on those engines. Get plugs for a 71 up model. R44TS. or r45ts if you need a hotter plug.
1972 Chevy c10 Cheyenne Super
#61770 06/18/2006 5:38 PM
As of the end of June, DELPHI (formerly AC Delco) will no longer be in the spark plug business. If you have not already noticed, about a year ago they stopped making EVEN number plugs (ie 42, 44). So if you have an old parts house better buy out their stock or use e-bay
1942 G5106 1.5-ton Chevy cargo dump Gallery page
Old Dominion Stovebolt Society
T/Sgt. Gott (28 years of service with the USPP)
1940 Chevy G506 4112 cargo dump
1942 Diamond T G509 969A 4 ton wrecker
1942 Ward LaFrance G116 series 2 10 ton wrecker
1944 Ward LaFrance G116 series 5 10 ton wrecker
1931 Ford AA with a WEAVER crane
1944 Sterling HC 165 tractor
1944 Autocar U7144T w/ 10 ton trailer
#61772 06/18/2006 9:28 PM
I may try Motorcraft next time. Champions break real easy & there is nothing inside of them. I,m serious it is hollow from the term to the shell.
#61773 06/20/2006 7:04 PM
I guess the era of the once quality made AC plug is over. Time to adapt. I have had pretty good luck with Autolites on my small blocks. I assume they would work ok on my inline. A little trivia TooMany, F___d used a Quadrajet on their Boss 429 to meet federal emissions. And Pontiac used a F___d top loader 3 speed in the late sixties as their standard tranny. Sorry folks got off the subject.
