Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (cmayna, jay d, 2-Ton, 2 invisible), 44 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#617650 02/07/2010 5:16 PM
Apprentice
Apprentice
the guy I bought my truck from used a disc conv. where the rotors went on the original spindles, which was cheaper to buy, well the conversion pushed the front tires out approx. 2" on each side, so the front is about four inches further out then the back, then he bought new chevy wheels and rings, what do you all think is the best thing to do, have inset wheels made for the front or replace the set up,, thanks for any opinion's or help
2" each side??!! That sounds like an awful lot.
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
I installed the front end upper & lower "A"'s along with spindels & all from a 1982 chevy truck & only had to drill a few holes. worked great & have front disc. Did not throw the wheels out at all.
