4 members (Bill Hanlon, TooMany2count, 55shaker, Gdads51), 109 guests, and 2 robots.
Topics128,076
Posts1,056,280
Members48,441
6 heaven
6 heaven
I would like to replace the original points distributor with an electronic one. Has anyone used the replacement new HEI assemblies? How about a replacement aftermarket 1 barrel carb instead of the Rochester? Or any advice where to purchase any of these items. Thanks!
I just got one of these for my 250 from langdons and it works great. http://www.stoveboltengineco.com/acartpro/product.asp?productid=125
as far as the carb goes, I re-built my monojet and what a difference!
Good luck with it!
Riding in the Passing Lane
The 78 up factory HEI fits that engine perfectly. The Roch. model B in the early 60's is not a bad carb. It has been beefed up in the throat area to prevent the warpage problems they had on the earlier ones. The monojet from 68 up is a good carb. if you get the manual choke or electric choke model. Some Stovebolters use the Weber carb. with an adapter & say they work real good.
1972 Chevy c10 Cheyenne Super
